14 Czerwca 2026, 16:47:37 czas Polski
Autor Wątek: Odp: Bosch REAXX  (Przeczytany 685 razy)
Offline cumbajszpil
  • Wiadomości: 403
  • Volenti non fit iniuria
Odp: Bosch REAXX
« dnia: 23 Kwietnia 2017, 14:56:40 czas Polski »
Elektrycznie
How It Works
#1 -- Detect
The blade carries a small electrical signal.
When skin contacts the blade, the signal changes because the human body is conductive.
The change to the signal activates the safety system.
#2 -- Activate
An aluminum brake springs into the spinning blade, stopping it.
The blade's angular momentum drives it beneath the table, removing the risk of subsequent contact.
Power to the motor is shut off.
All this happens in less than 5 milliseconds!
#3 -- Reset
Resetting the saw yourself is easy. Simply replace the blade and affordable brake cartridge and your saw is operational.
The entire reset process takes less than five minutes.
Other safety features include a main power switch with lockout key to prevent unauthorized users from turning on the saw and a large start/stop paddle with hands-free shutoff that can be stopped with your knee, allowing you to safely stop the blade even when both hands are busy.
